TwinTurbo.NET: Nissan 300ZX forum - Test your fuel pump and your fuel pressure. That is likely
Subject Test your fuel pump and your fuel pressure. That is likely
Posted by doug8867 on April 25, 2008 at 12:04 AM
  This message has been viewed 529 times.
In Reply To Problems, problems, problems. (video included) posted by 94redZee on April 24, 2008 at 08:35 PM
Message your cause of the slow starting and bogging down. Pressure at idle should be
37psi, with throttle open it should be 44psi.
If you've disconnected the neg. battery cable for 10 minutes after relocating
your knock sensor and you still have the code 34, then check the wiring
leading to the knock sensor harness connector off the main harness, it may
be broken and need to be spliced back together.
Noise sounds like something is hitting the timing belt covers or fan.
